Long time lurker finally sacking up to ask a question. Here’s the deal – have a 73 914 with a Renegade conversion package (9 inch clutch upgrade) with about 1,000 miles on it. Was driving one day and I noticed the clutch pedal wasn’t working like it was supposed to, had the broken clutch tube symptom. Happened all of a sudden like too. Drilled some holes at the front tube mount point and checked the tube while pushing in the clutch– it was O.K., didn’t move at all. Anyways, I tack welded it through the holes while I was there. From what I’ve found on the site your supposed to have a little bit of slop at the pedal before the cable even engages and applies force to the throwout bearing arm correct? If I set it up like this, with the clutch pedal all the way to the floor I can feel the pressure plate trying to grab the disc – not quite completely releasing. The only way I get this thing to shift smoothly is to have tension in the cable but am I screwing up the throwout bearing and/or pressure plate fingers? Is it normal for this aftermarked clutch setup to have tension in it? Is the cable bad (Terry cable) and acting like a big spring (stretching)? Or perhaps is the pressure plate setup not matched to the travel the throwout bearing provides? WTF??? Any input is appreciated.
Thank you.
You friend, Johnny G.
P.S. - I ordered a GEMO cable from GPR as a backup and am thinking of putting it in.
