QUOTE(zen motorcycle @ Feb 22 2007, 03:56 PM)
my shift linkage seems to be eating the nylon bushings for breakfast lunch and dinner. Has anyone run across this before? Also I am leaking gear oil throught the shift linkage attached to the case. How hard is that bushing to change?
thanks
I just recently removed the cheaper version of a shortshifter from mine (it had gotten into the clutch tube and caused all kinds of problems). Anyway in the process of doing this I disassembled and overhauled the entire shift linkage: replaced all of the bushings, resurfaced both the front and rear shift rods-which I then primed and painted-replaced the spedo angel o ring, shift selector shaft, seal, and o-ring, and replaced all cone screws. The shift selector shaft, shaft seal and o-ring, is the area that you mention is leaking on yours and is a pretty easy fix. In one tech article that I had read it stated that roll pins in the shift selector shaft would have to be pressed out, but I was able to get mine out with a hammer and punch. The hardest part of the whole project was getting the firewall bushing installed. With the overhauled linkage and the original shifter, the car shifts as well as any car that I’ve ever owned, and is a 100% improvement over the short shifter that was in the car when I purchased it.
