QUOTE(Justinp71 @ Feb 23 2007, 09:50 AM)
Slits... I like your setup, it seems easy and fast.
But how did you attach the 1/4"-20 nuts to the car? Did you bolt in from the back side to hold it down? I wonder if you can get black bolts, then they won't stand out.
Since I got so many 914 CIS guys on this thread... Have any of you guys put a oil cooler in your car? and kind of mpg do you get? I get around 22mpg.
Yes, the standoffs are bolted from the bottom with very short 1/4X20 fastners. I just took a drill and drilled through the engine lid and support and put the pieces in place.
I suppose you could paint them.
I have tried several oil coolers as my engine can run 130 C. Mounting them in the rear above the transmission I've gotten down to 112 C. There are several threads on the need or no need for coolers .... there are as many opinions as assholes. I guess it comes down to how good your engine is. One says all the way to 2.7 without .... one says 2.2 and up. Whatever ... it's going to come down to when you drive it what temp you're going to see.
I'm still resisting installing a front cooler 'cause I'm a lazy ass and don't want to cut more holes and run lines.
I've never checked the mileage .....
