I have a wierd issue maybe one of you know what is happening. I have a intermitant fuel pump problem. I was wondering if the ignition switch has anything to do with it? I know dumb question, but I have to ask. 95% of the time I turn the key to the on position. I hear the fuel pump kick in for its 1.5 sec prerun. Here lately that has not been the case. I hard wired the pump up to the fuse box to test the pump's consistant functionality, All is ok in that dept. Would a bad or going bad ignition switch cause this symptom?
Thanks!!!!
