I HAVE 40 IDF WEBBERS NOT 44 IDF'S AS EARLIER POSTED>>>>WHEN I COME TO A STOP I HAVE TO KEEP THE WINDOW CLOSED DUE TO FUME ODORS FROM EXHAUST OR WHAT I DONT KNOW......HOW DO I GET RID OF THAT FUME SMELL
I CHECKED THE JETS ON THE 40'S AND THEY ARE WHAT WEBBER RECOMMENDS FOR THAT CAR.....F11 EMULSION TUBE AND 1.15 MAIN JET; I ASSUMED ALL THE OTHER JETS WERE THE STANDARD SIZES FOR THAT SET UP.....AS I DISCUSSED WITH THE SELLER BEFORE I BOUGHT THEM WHAT TO USE
THE FUEL MIX MIGHT NOT BE PERFECT BUT THE PLUGS LOOK FINE AND THERE IS NO VISIBLE EXHAUST CLOUDS OR SMOKE
ADDITIONALLY- I PULLED THE PLUGS AND THEY LOOK PERFECT....LIGHT BROWN CONDITION NO PITTING OR DEPOSITS
BUT I STILL HAVE THE SMELL......WHAT DO YOU RECOMMEND
1. TAKE TO A SHOP AND HAVE THEM RUN SMOG MACHINE TEST TO DIAL IN PERFECT FUEL AIR MIX...REMEMBER I HAVE NO SMOG EQUIPMENT ON IT?? OR
2. WHERE THE OIL BREATHER TUBE RUNS OUT OF THE TOP OF THE OIL CAP....I ROUTED IT UNDER THE CAR ON THE DRIVERS SIDE.....SHOULD I RUN IT THROUGH THE CHARCOAL CANNISTER BEFORE IT EXITS/?
3. THE CAR RUNS STRONG ( FOR A 4 CYL) AND OCCASIONALLY HAS A POP SOUND FROM CARB....LIKE WHEN 1ST STARTING OUT...BUT HAVENT NOTICED AFTER RUNNING 5 MINS.....AND MY UNDERSTNDING IS IF ANYTHING THE POP IS BECAUSE ITS TO LEAN...
4. TIMING SEEMS GOOD....NO RUN ON AND NO POPS ON FULL ACCELLERATION
IT STINKS AND I HAVE TO KEEP MY WINDOW CLOSED....
GOT IDEARS???
SO....
ive taken 1.8L and put 96mm big bore on, balanced pistons
a newer cam better tuned for the carbs,
40 IDF webbers, Monza exhaust
complete rebuild
removed all heater boxes and dammed the ports
all smog equip removed
