QUOTE(ahdoman @ Feb 24 2007, 05:50 PM)
FYI - Running Dual Dell DRLA 40's. Is there supposed to be a gasket between the manifold and the head?
usually a thin paper gasket. i ran the much thicker, stock FI gaskets. they create a heat barrier between the heads and the manifolds that prevents the fuel from boiling in the carbs after a long run.
while the car is driven, the manifolds and carbs stay cool, but as soon as you get to a stop, the heat creeps up the manifolds from the heads and the carbs can get pretty damm hot.
the thicker FI gaskets help preventing that ...
Andy
