Here is Mr. Zieglers note that accompanied the car. Please note that Konrad says "needs to be rotated and brought back into running condition with care"
here is our repair order (excuse the messy hand written example we are so far behind in the repair department that we are not using our computer generated invoices! (also for you scrutinizers, the 12 oil is special 80/90 and by the pint (not engine oil!!!!)
Here is Sean's version of the story, along with my interjections:
To preface Sean and Dan's reply, Konrad has a very nice 1971 willow green 914 that is very straight rustfree and a great candidate for a full restoration. We probably love it more than he does!!!!!!!!!!!!!!!!!!!!!! This issue should have been a non issue as there was some communication breakdown somewhere, and we can only tell it as it is. As we all know 914s these days need more restoration than repair so it is not a simple thing to tell someone: "Yes water pump replacement on your 2003 Ford is 169.53 parts and labor" Every repair must be taken on its own case by case basis and when one has a car towed in and inoperable, and wants to make it operable, the repair shop must analyze the scope of the work, but more importantly address the core issues one by one a penny at a time until able to make the vehicle run, and then hone in on the specifics to make the vehicle operate reliably. Konrad's car was the typical case, a 35 year old 914 that we had not seen before and that had not been running in awhile, had not been serviced properly in the past, and that the customer had given up on making it run, and finally had it towed to a place that would take the time and patience to bring it back from the grave (so to speak)
Konrad's dad first called me saying that his son had tried to work on his car, could not get it running and really did not know what he was doing, and could we help. The current problem was a bad rocker arm stud, and he asked how much it would cost to tap and replace it. I explained over the phone that if we could access it from the outside, around 400 Including parts and revalve adjust, which would cover us removing the trailing arm and dropping down the engine to access.
The car showed up here several days following and alas when the driver dropped it the drivers window immediately fell down! This was the signal of things to come. Below is the narrative of Sean and Dan (I will interject if appropriate):
"Konrad Ziegler brought his car to us and told us he had not driven the car in six months but it had been in great driving order with the exception of a nasty engine noise.
He explained that he knew the car had a broken rocker stud. That being the case George told Konrad that if the engine was to stay in the car the bill could be as little as $400.00. We were surprised to find that when we went to push the car into the shop it was stuck in second gear because the bushings were broken, missing, and worn...not to mention that the shift console, first reverse bias had broken free and the plate had to be rewelded (I must say that we did not charge for this operation on his bill)
After the six of us pushed the car in and pulled the valve cover we could see that Mr. Z had attempted to drill out the stud but to no avail. This made what could have been a very simple procedure, vastly more complicated. Upon closer inspection, we found the cause of the problem: the rocker assemblies were all being held in place with lock washers and nyloc nuts of the wrong thread pitch, and the rocker assemblies were actually installed out of sequence, intakes on exhaust and vice versa. We replaced, retapped, and readjusted all.
Because of the complications, the engine had to be pulled and of course the cost naturally went up. This had been previously established as a possibility with Konrad's dad before the car was dropped off and the line of communication here, seemed to be direct.
While the engine was out we found that a large pair of needle nosed pliers had been in the fan for quite some time (probably some of the noise that Mr Ziegler had described). this of course had broken about half of the cooling fan blades. We then added the cost of a used fan to a list being compiled for round two.
The round two list consisted of cv axle repack, front wheel bearings (about to fall off the car) a leaking left front caliper, shifter bushings, the previously mentioned cooling fan, the alternator belt, the muffler bracket (missing) and the engine mounts. (Mr Z had included two rear 911 mounts to install for the transmission mounts, but we had previously determined that they were ok and he did not need them, but they could be used to replace the engine mounts as one was indeed broken)
At this time Mr Z. was called and told what had been done what he had spent and what was needed to get the car into a drivable state "with care" as stated in his letter. As I understand, the conversation between George and Konrad outlined that Mr. Z didn't have a lot of money and was pushing his budget but understood that the work needed to be done and was willing to spend a "little more." "
Let me (George) interject here. I had a discussion with Konrad here and informed him that we would have to spend about 2500 here to repair all of these things and he acknowleged that figure. I also told him that we of course could spend a lot more including a thorough major service to make the car reliable. He at that time questioned why the cv joints needed to be repacked as he had a fairly recent receipt showing that they had been replaced. My mistake is that I found out when Dan had removed cleaned and examined the cv joints that they were indeed WORN OUT and needed immediate replacement to get the car operable. I took it upon myself to authorize Dan to replace the axles with rebuilt ones as repacking was hopeless. I called Konrad to come out and see the axles for himself which he did, and he saw and acknowledged the rest of the work approved on the phone to get the car operable.
I think that in Konrad's own words, "George then gave me a call to say that everything was finished but had seen some problem areas that needed to be addressed. George told me that it would take some "tweeks" to get it in perfect running order, and it should cost 2000 to do everything. I thought that he meant 2000 dollars inclusive of the engine work, but none the less I told him "do what you need to get it running, but 2000 is way out of my price range."
To return to Sean and Dan's narrative:
"Mr Ziegler even came by once the engine was back in the car and Dan explained in great detail what had been done and what he was doing.
That was Friday. On Monday, Mr. Z. was called and given his total of 3175.52 A total that he disputed. So I went over every part and every hour of labor with him after faxing him a copy of the work order.
Now convinced of the total he argued that he had not agreed to the amount of work that was done and said he had only agreed to 2000.00 worth of work.
He then made it a point to tell me he was an attorney and could "make things very rough for me". I also told Konrad that we would be happy to remove parts from his car (specifically the previously unapproved rebuilt cv axles plus any other parts GH) until we could reach a predetermined budget starting with the cvs. which made up a large portion of the post estimate work. At this time he suggested that I "eat" the $3000.00 plus bill and simply buy the car from him for $15,000.00 (fifteen thousand dollars). As I hate to defame someone's character, Mr Ziegler seemed to me to be overly aggressive and quite dishonest."
(these are Sean's observations and not mine!!!!!!!!!! GH)
" I have abbreviated the extent and depth of the discussion and negotiation. "The simple fact that he said the car was driving just fine six months ago tells me that he knew he was setting us up to get work done for free. In the end he succeeded, I had to do a lot of other "tweeking" to get the car to run. I told him among other things, that I had done my best to adjust the shift rod to regain command of all of the gears, but first gear was entirely gone! He told me this was a fact he had been well aware of and had failed to mention.
The final thing that I think is at the crux of this dispute is that Mr, Ziegler produced a repair work order from another shop showing that they had replaced the cv joints and added one quart of ANTIFREEZE!!!!!!!!!!!!!!!!!!!! "
(wouldn't you too be leery about taking your car to the next repair shop after seeing a bill like this????? GH)
Thank you for the narrative Sean. Dan, Sean, and Konrad, are all young guys and often times misunderstanding leads to tempers getting out of hand about something that could be easily be solved. I admire all of our young staff here for ALWAYS remaining cool headed and everyone here treats every customer with respect and courtesy. They will continue to do so, and one can always be assured of a quality repair/restoration here for a very fair price, and we will tell you financially always what you are getting yourself into with these old cars!!!!!!!!
And finally here is a list of other things we noted about this 914
EN 914 ZIEGLER
· Front tie rods and ball joints need to be replaced
· Front drivers caliper leaking (we rebuilt)
· Lug nuts are very loose (we tighened!)
· Rack and pinion cover bent
· Heater control hose is off (we reinstalled)
· Passenger Rocker panel cracked
· Broken engine mounts (we replaced)
· Fuel pump boot missing, gas leaking at injector line (we replaced the injector line
· Shift rod boots missing, shift bushings are bad, needs adjustment (we replaced the bushings and rewelded the shifter base where it was broken
· Rear muffler bracket missing (we replaced)
· Swing arm is loose
· Clutch tube cracked at the firewall and probably at the front, no clutch cable boot installed
· Reverse light switch boot missing
· Starter is loose (we tightened)
· E-brake cable boots missing/ stuck cables and handle (does not work!) has bolts installed instead of pins at the calipers
· Some passenger engine shelf rust
· Shifter bushing “at firewall” cracked in half (we replaced
· Heater hose clamps missing
· CV joints dry, may need replacing were totally shot! (We replaced with rebuilt units)
· Low transmission fluid (we changed the fluid)
· Dash pad shrunk/ cracked dash
· Missing seat belt bolt covers (plastic)
· Seat rails in need of lubrication
· Engine lid cable is missing the cable release back pad plastic washer
· Missing drivers door panel arm rest / pocket (off)
· Battery dead (we charged and checked the charging system
· Back pad light wiring is not making good connection
· Latches in need of lubrication
· Engine lid drain pan off
· 914 badges missing backing
· Targa top latches (in trunk) broken (4 of 4)
· Both trunk (rear) seals cracked and brittle
· Cracked drivers tailligh
· Needs air filter cleanup and relubrication water in airbox (needs cleaned)
· Engine lid seal missing
· Relay board cover cracked
· Bad trunk hinge cup repair (passenger is cracked
· Cracked/ripped intake boot (we repaired as the new part is NLA)
We have been in business now for over 29 years and pride ourselves in knowing our way around a 914. We are not out to take advantage of anyone. Konrad is welcome back any time to continue his restoration and get the other things done as his budget allows. All of our work is fully guaranteed and we stand behing it. We will leave no one out in the cold who owns a 914
