r_towle
Nov 25 2003, 01:12 PM
Hi,
Aside from taking them apart, how could I tell what gears are in what tranny???
If I open them up, are there numbers on the gears that I could find without taking it apart further???
I may just put each one in the car, drive it and see based upon speed/tach what I have....
Any ideas???
Rich
Brad Roberts
Nov 25 2003, 01:16 PM
I gave up on the letters. I count the teeth. I mark one tooth with a paint marker and count from there.
A lot of the times.. I mark the top of the tranny with what it has in it.. I have seen Brad Mayeur do this also.
B
Brad Roberts
Nov 25 2003, 01:18 PM
You could put the tranny into each gear and count the revolutions. The R+P is the constant. Mark the input shaft and turn the output flanges.
B
r_towle
so, after I count the teeth, hopefully you can decifer what they were trying to do...
Looks like two of them have no first gear...just deleted...
Rich
Qarl
Nov 25 2003, 01:22 PM
What are the stock gears? (Letters?)
Brad Roberts
Nov 25 2003, 01:24 PM
That is "different". My guy's have at least 1-2 tranny's with 904 main shafts or custom shafts that allow 3rd gear to go in place of 1st... so they have 5 "race" usable gears. Have to push/pull the car to grid or shutter it in a third gear.
If we have a box with first.. we use it.
B
Brad Roberts
Nov 25 2003, 01:29 PM
ZD is stock 4cyl 5th
F is stock 4cyl 2nd
A is first
I forget the stock 3rd/4th
Typically people will build a M3/S4/X5 box. This is a cheap racers box to build.
B
