furthermore, has anyone here used an accusump on their engine?
I've been reading about them on pelican and some other boards.
One issue with it is you need a check valve to prevent pressure returning to the oil pump when there's a pressure drop. Since there is a check valve... where would be good to tap the case for this accumulator device? On the oil cooler tower perhaps? or maybe in one of the galley plugs that are already tapped?
Its hold oil under pressure, and if there's a drop it releases the oil for 30 seconds for whatever to compensate so somewhere that is after the check valve but before the bearing passages. Is there an oil system map?
I haven't bought one yet, but i'm home wasting time on the thought.
http://www.accusump.com/
