QUOTE(SGB @ Feb 28 2007, 09:51 AM)
Helper springs is a great idea. I've asked this same question- think it was in August. In my flappers, the asbestos (I'm guessing) ring had come lose, so right now I have bad sealing too. I've adjusted and readjusted the cables too. In fact, it leaked just as much hot air with the cables disconnected. There has to be some kind of high temp capable stuff we can use to make new ones. Where are the fabricators? Hey out there! Bruce, or Engman, or Dr Evil, or ...
It takes a LOT of prolonged bad weather to screw these simple valves up. And, they are very simple.
If you can make suitable adjustments via the cables, it's time to replace. These are probably the last of the914 bargains out there. Not only can you pick them up regularly on eBay for $20, but you can but brand new ones for $65.
Need heat - fix it!
BTW, I think you're correct about the asbestos ring. Doen't bother me though. I stockpiled asbestos brake pads 20 years ago & will never have to worry about idiotic dusting or premature wear. It wasn't broke, so I didn't fix it!
