QUOTE(sww914 @ Feb 28 2007, 01:32 PM)
If I don't know, I start with 8, check it after it starts, add another one if it's not touching the stick, add another 1/2 at a time until it's just touching the stick, and then drive it until it's warm and check it as usual.
Cool, I was wondering the method... I have a problem, what is happing is not what you described.. I was not sure, but you have shown the light, thank you for your insight of what should be a normal check your oil stick deal..
School of Dummy-hood...yours truley
Cause of problem:
While I was boiling out my oil tank, the radiator shop forum dropped a quick question, DO YOU WANT TO SEAL IT, IT LOOKS LIKE IT NEEDS IT!!
I said a off the top of my head, quick answer back. It was a very, very, very, very wrong answer: "YES seal it"
Now class, what problem was caused by my hasty, quick thinking I am going to take care of, "for sure" a maybe down the road leaky oil tank problems... well it does not leak... thats good I guess...
The oil tank, after sealing was clear of obstructions at hose outlets and inlets, they all checked out fine... no loose dubree anywhere
lets have some fun with it anyway...
