Trying to get the fan housing out of the front trunk. Have removed the 2 10mm bolts from the side. Removed the 6 slide on clips from the front. I know there is a cable connection under there somewhere. Is there only 1 cable? What else has to come off to get this out? Electrical connection somewhere?
I remember from my other 914's, once the 6 slide on clips were removed, the front cover (the piece with the Behr printed on it) would seperate from the bottom housing. This 74 doesnt seem to seperate. Are these pieces glued together? Don't want to pry on it with a screwdriver because it will break.
Thanks for all the tips / help.
