Full Version: Are 914/6 & '69-'73 911 mufflers the same ?
Lightweight_911
Is the original Factory 2-in 1-out 914/6 muffler the same as that used on '69-'73 911's ?
SLITS
Ah, yes!
DanT
I thought the original 6 mufflers were actually tucked up a little closer to the body? confused24.gif
I know the 911 mufflers fit, but I thought they were slightly different.
Aaron Cox
tips exit in a different place (ever so slightly) if i recall correctly...
dr914@autoatlanta.com
correct the tail pipe angle is different, and you can make one work by heating and bending the pipe or removing the rear valance!!!
Dave_Darling
Or by switching to the 72+ 914 rear valence; evidently the "notch" in that is in the correct place for the 911 muffler's tailpipe!
--DD
