QUOTE(dflesburg @ Mar 3 2007, 06:02 PM)
Help!
Last time I took these apart was 13 years ago.
I don't remember how I did that.
bolt off,
stub axle out
how to get the hub off?
Wait a minute. If you had them apart 13 years ago, why did you put them back together? Your car has been apart longer than that.
I bet you are you installing the e-brake backing plates and associated hardware. Good for you.
Did you try calling? I was out.
I use my 20 ton press and a suitable piece of tubing. I think a 30mm Impact socket would work, but I don't like beating on my tools. Many moons ago when I didn't have my press, I used a piece of black iron pipe (1" or 1 1/4" don't remember) and a 5lb sledge to coax the hub out of the bearing.
You will destroy the rear wheel bearing in the process, so you might as well order a pair if you already don't have them.
Call me if you still have problems. I'll be stripping and refinishing more cabinets all day tomorrow....
