bd1308
Mar 4 2007, 07:44 PM
I'm looking for a local tail or side-shfit tranny.
It needs to be in one piece and spinning.
It also needs to be installed into a bus, the mounting is different involving mounts @ the bellhosuing.
So.Cal.914
Mar 4 2007, 07:54 PM
Get yourself a early 911 901 trans. No need to flip the ring gear and more
condusive to a bus fit.
bd1308
Mar 4 2007, 08:00 PM
Hmm....
John
Mar 4 2007, 08:10 PM
QUOTE(So.Cal.914 @ Mar 4 2007, 05:54 PM)
The shift rod would at least be pointed forward then (and the R&P are in the proper orientation).
Aaron Cox
Mar 4 2007, 08:35 PM
QUOTE(John @ Mar 4 2007, 06:10 PM)
and it has a mounting boss on the bottom....
fab up a bolt on hanger and you are good!
the shiftlinkage is easier yet!
bd1308
Mar 4 2007, 08:53 PM
Vvvverrry INtresting....
and the mounting is the same?
So.Cal.914
Mar 4 2007, 09:20 PM
QUOTE(bd1308 @ Mar 4 2007, 06:53 PM)
Close enough, you may need to make an adapter for front, rear mounts and the
shift rod. But very little compaired to a 914 901.
911quest
Mar 4 2007, 10:14 PM
It's also matters which year bus your talking about split window, bay??
Cap'n Krusty
Mar 4 2007, 10:53 PM
I've done it, and I can talk you through it. I can also supply you with a tranny. The Cap'n
bd1308
Mar 4 2007, 11:18 PM
My buddy will be very VERY happy.
Eric Taylor
Mar 5 2007, 02:02 AM
this is a really intersting idea. How would the gearing be for the bus? Would you get better milage with 5th gear?
Eric
rick 918-S
Mar 5 2007, 08:59 AM
5th gear would be nice if you have the power to shift into that gear...
Then you need to remember the cooling depends on the RPM's.
Jake Raby
Mar 5 2007, 09:01 AM
Better watch those gear ratios if your bus is a bay window!
Lowering engine RPM is a BAD thing in a Bus application as that slows the cooling fan and increases load, both of which increase head temps!
The 901 will work fine in a Bus, I am slapping a 915 into my company Bus with a 2.2L Intercooled Turbo CIS injected MassIVe 4..
Just don't try to drop the operating RPM at highway speeds by much, the aerodynamics of a Bus coupled to it's weight need increased engine RPM and cooling system pressure to provide normal engine temperatures.
