Full Version: Foglight wiring
watsonrx13
OK, I'm ready to install the foglights, but I'm not certain how the yellow/white wire is connected. I understand that it's suppose to connect to the screw that holds the bezel, but mine don't have any end connection, just plain wires. Should there be a loop connection for the screw to pass through?
Here's my pic.... does anyone else have one of theirs?
-- Rob
Doug Leggins
Here is where the yellow/white wire should be connected.
watsonrx13
Thanks Doug, I'll check the lens part tomorrow....
-- Rob
watsonrx13
Doug, I checked the lens portion and found the set screw that holds the yellow/white wire. I hooked one side up and it worked.... clap56.gif
Now, I need one of the allen-head mounting bolt and and one screw that holds the retaining clip, anyone have these? biggrin.gif
Thanks again for the photo....
-- Rob
Doug Leggins
Rob - I have the hardware that you need. Let me know where to send them and I'll get them headed your way beerchug.gif
watsonrx13
Thanks Doug, PM sent....
-- Rob
