Series9
Mar 9 2007, 07:16 PM
Slits sent me a fan for Waide's engine and it doesn't fit inside the housing.
As far as I'm aware, there are only two sizes: 245mm and 226mm ('78-'79 only)
I have a 245mm housing. This fan appears to measure 250mm, but I'm unaware of anything over 245mm ever being produced.
All of the 245mm (early, late and 5-blade) are interchangable. Ron sent an early style 11-blade. It should fit.
Liz's early 11-blade does fit.
Anyone?
sixnotfour
Mar 9 2007, 07:19 PM
really early sandcast alum ring fan you have there .
sixnotfour
cut it down in a lathe .
sixnotfour
Mar 9 2007, 07:20 PM
unless Slits has the alum. ring then he should sell as a pair.
Series9
Mar 9 2007, 07:25 PM
I was hoping it was a part off of 114.
Slits could eBay it for $$$$.
I did notice the casting looked rough, but why can't I find ANY reference to this size fan?
SLITS
Mar 9 2007, 07:31 PM
I have the ring .... he didn't request it.
I didn't sell it .... I just sent what he asked for.
Now, if the fan was in an engine fire would it swell 5 mm?
I am headed to the parts stash to get the number off the ring, but as I remember it was 3R.
Series9
Mar 9 2007, 07:41 PM
Hot enough to swell=Hot enough to melt IMO. So I don't think so.
The fans should be magnesium. How can I tell this is aluminum without filing it? I can tell the difference between mag and aluminum when I file it, but otherwise????
sixnotfour
Mar 9 2007, 07:46 PM
255 dia.
245 on top of 255
difference in rings
sixnotfour
Mar 9 2007, 07:55 PM
Fans are mag ,The ring is alum on the .03
Series9
Mar 9 2007, 08:32 PM
QUOTE(sixnotfour @ Mar 9 2007, 06:55 PM)
Thank you very much.
Ron, eBay calls.$$$$$$
sww914
Mar 9 2007, 09:06 PM
QUOTE(Series9 @ Mar 9 2007, 05:41 PM)
If you hold a torch to it and it melts, it's aluminum. If it turns into a flare, it's magnesium.
davep
I believe there was also a 250mm. Rare though. Great thread here:
http://forums.pelicanparts.com/showthread....threadid=332048
