jimkelly
Mar 11 2007, 07:42 AM
i noticed that a wire going to the coil sends a signal to the light - is this correct or could this be my problem causing the flickering?? if i disconnect this wire the light goes out. jim
ClayPerrine
Mar 11 2007, 07:46 AM
QUOTE(jimkelly @ Mar 11 2007, 07:42 AM)
If you are seeing that, then you need to put a mechanical oil pressure gauge on the car and check the pressure with it. If the readings are OK, then replace the sender. Otherwise you may need some engine work.
TheCabinetmaker
Oil pressure light does not attach to the coil. It goes to a wire that will come out of the harness near the center of the case on the passenger side
jimkelly
Mar 11 2007, 12:10 PM
i do not have my haynes with me and still have lots to learn - but my engine is a GA001xxx and off the harness that goes near the coil have a black wire that goes to the coil and a green/brown wire that (when plugged onto my coil) makes me oil pressure dash light blink wildly. if not to coil - where does this connect to. note: my car is a 1975 wiht a 1973/74 engine. thanks !!!
So.Cal.914
Mar 11 2007, 12:31 PM
It should be a green and red, I think, wire (old wire= red may look brown) it
should connect to the oil preasure switch. You will find it behind the dizzy (torwards
rear of car) thru a hole in the sheet metal, only a few inches from your dizzy
IIRC.
jimkelly
Mar 11 2007, 01:05 PM
ok - got it -- but -- sensor must have been previously sheared off - no top ha is there any other place on engine to get pre4ssure from ??
jim
[quote name='So.Cal.914' date='Mar 11 2007, 10:31 AM' post='873348'
IIRC.
[/quote]
So.Cal.914
Mar 11 2007, 01:09 PM
[quote name='jimkelly' date='Mar 11 2007, 12:05 PM' post='873370']
jim
IIRC.
[/quote]
[/quote]
Replace sensor with a new one, simplist fix for you.
jimkelly
Mar 11 2007, 03:13 PM
here it is...
Aaron Cox
Mar 11 2007, 04:07 PM
looks like a drill and EZ out operation?
i believe the thread is almost identical to 1/8 npt,
So.Cal.914
Mar 11 2007, 04:10 PM
QUOTE(Aaron Cox @ Mar 11 2007, 03:07 PM)
jimkelly
Mar 11 2007, 04:11 PM
thanks guys : )
Aaron Cox
Mar 11 2007, 04:12 PM
what did you coil's oil pressure look like BTW?
So.Cal.914
Mar 11 2007, 04:15 PM
About 10,000 volts PSI.
Aaron Cox
Mar 11 2007, 04:16 PM
back to studying......
jimkelly
Mar 11 2007, 04:20 PM
guess i am the first with an oil cooled coil : )
Aaron Cox
Mar 11 2007, 04:24 PM
(actually, most coils do have oil in them .... shake one if you have one out.... unless it is epoxy filled for high vibration applications)
Brando
Mar 11 2007, 04:36 PM
QUOTE(So.Cal.914 @ Mar 11 2007, 03:15 PM)
The higher your RPMs the more it would flicker eh?
SLITS
Mar 11 2007, 09:31 PM
QUOTE(Brando @ Mar 11 2007, 02:36 PM)
Just after the light turned solid the engine threw a rod!
