I've decided that since I'm getting the car painted I might as well pull the tank and fresh air box and do it right. I do have some fuel in the tank and just need something to plug the fittings on the bottom so I don't end up with a lake of fire in the garage.
I'm going to replace the lines from the tank to the ones that run through the tunnel but can't remember which size.
I seem to remember either 12mm or 5/16.
I am running carbs so the high pressure FI lines aren't needed.
