After driving it a month or so with 327, 930, M koni struts and brakes and
re-drilled 914 rotors on 911 hubs w/ 930 axles, I parked it and started the
winter renewal. First, I bought a gmpp shortblock and added AFR 180 heads,
had comp cams grind me a flat tappet hyd cam (230 236 w 490 lift). Still
messing with the dash, can't decide whether I prefer the cf Getty or the
stock dash. Got a cage and removable brace stiffeining kit from CFR and will
install them with the "GT" stiff kit.
Installed poly bronze up front.
I've got a Holley mpfi intake and after I sort out the new motor with a carb
I'll see if I can make it work with megasquirt 2.
Mark sent me his first h2o heater setup and that will probably go in this weekend.
Misc thoughts after a whole bunch of tanks of gas:
Cable shifter works great
I am SO glad I spent the money on a strong drivetrain
The weight behind my shoulders is noticable
(this is 195s on 6.5 minilights all around)
It sure is fun having a FAST 914. My 2.4 cis six was quick, but the 327 is
fast. The 350 should be, well, faster. And the Al heads should save ~40 lbs.
happy gnu year!
patrick
