I made an engine crank to roughly test my cylinder pressures before I completely tear down my engine. It connects to the front pulley and worked pretty well. I wanted a baseline to judge the work I am about to do.
Cylinder 1 - 112 psi
Cylinder 3 - 110 psi
Cylinder 4 - 112 psi this is going pretty good for a cold engine and a hand crank.
Cylinder 2 - 25psi fading to 0 psi (insert a Hommer "dope")
I guess I will have more work to do. Air is bleeding past the exhaust valve. (and yes I did check to see if there was clearance between the rocker and the valve when it was closed)
It just adds to the fun of owning a teener. (and the pocket book )
