QUOTE(Tobra @ Mar 17 2007, 10:21 PM)
It is probably leaking out, you get a little bit of moisture in from the vent on top, most of them leak some, the speedo drive is a favorite spot to drip.
How long was that oil in there?
Well the speedo drive seal was just replaced, but I think there is a small pin hole where the rear muffler cross bracket brace attaches to the tranny? It looks as if someone machined a ledge right above the speedo drive for this brace. Is this a stock ledge? Maybe they machined it to far? What kind of compound should I use to fill this tiny hole (size of a pin head) JB weld? What do you think?
I plan on pulling the transmission within the week to seal things up. I have a leak at the main shaft seal as well...tranny fluid fo sure, not oil. The oil is a mix of new and old. I have been topping it off every couple of weeks, and this last time I put a little too much in and a whole lota Latte out...so I draind it and filled it with roughly 2 qts of 85w 140 from NAPA.
While I have it out should I just get a complete seal kit...is it a no brainer or am in over my head. I am not a mechanic, but I have replaced a Saab 900 clutch and of course my 914. BMW brake upgrade. Rebuilt the calipers and machined them to fit. Rebuilt the 914 master cylinder and lots of small misc. stuff.
Thanks for the input...
