So I completed my external cooler install yesterday. Fired her up, found a couple of small leaks: one at the cooler and then two at the mocal thermostat. Both leaks at the thermostat were where the brass fittings thread into the thermo (not on the hose side of the fitting).
I put a little extra muscle on each of the offending locations this morning and took her our for a spin. All dry except one of the areas at the thermo (same as above). Torqued it a little more...starter her up...still leaking.
Honestly I am afraid to get on it any more for fear of stripping it out. Any ideas anyone? It is a slow drip. Once the motor is running I can watch and see the oil slowly forming where the brass fitting mates with the body of the thermostat.
Help!!!
