Brad, I can't tell you how much time I have spent on your site educating myself and verifying my setup.
I think I've done a pretty good job refurbing this car that sat dead for like 5 years in the PO's garage. So please bear with me, I'm not the typical clueless guy wading through cracked and dry parts on his tired old DJET. I'm real close to having this car dialed, I just need a little expert advice.
The unknowns of your list, I accented in red as a matter of record, the one that stands out is the dizzy retard.
QUOTE(pbanders @ Mar 20 2007, 04:41 PM)
1. The engine is in good mechanical condition - proper compression, proper valve adjustment, good intake manifold vacuum, no vacuum leaks, hoses plumbed properly, no vacuum leaks, all systems in place (e.g. PCV valve system in place and valve working properly)
Compression is good, valves are adjusted,
haven't tested vacuum tested for leaks, all hoses new including runners, plumbed absolutely correct, brand new PCV.
2. The electrical system is in good condition - battery at proper voltage (at least 12.75V for a fully-charged battery with the engine off), charging system in good condition (13.6V to 14.0 V when idling)
I checked the charging system and it appeared good, but I will double check it tonight QUOTE(pbanders @ Mar 20 2007, 04:41 PM)
3. Fuel supply and pressure are good - must provide the proper output and be dead-on the factory pressure of 2.0 bar
Set the fuel pressure last night to just under 30lbs. My gauge doesn't read Bar. Also my injectors are all tested and serviced by witchunter. New SS fuel lines and all new FI hose otherwise.
4. Ignition system in proper working order - plugs, wires, coil, cap, rotor all new or flawless, plugs properly gapped, timing and dwell spot-on, dizzy mechanical advance in proper working order, points plate moving smoothly, vacuum retard cell operating (essential for proper idle operation), vacuum advance cell operating (if on a '73 TB, otherwise, plug it). If you have Crane/MSD/Pertronix, set up according to the manual.
New Plugs, New Magnecore wires, newer coil, cap, and rotor. Gapped at .028. Pertronix so no dwell. Advance plate checked out and ground wire appears good.
My retard cell is dead! doesn't hold vacuum MSD is set up correct. I sent my schematic to an MSD tech to verify before install.
5. FI system bits all the right part numbers and working properly - check my web page for info. TPS properly adjusted so that the idle switch is actuated when you close the throttle, throttle stop set so that you get a full 20 clicks when you open the throttle, MPS in good shape - either properly calibrated by someone on the list with the tools and know-how, or an OEM unit that hasn't been tampered with (or a rebuilt that's been checked out). Pull the ECU plug and check all the parameters at the plug with a DMM (procedure described on my web page).
All parts are correct for a 73 2.0. I checked everything when the motor was out of the car. Brand new TPS adjusted correctly when I had the motor out.
I'll have to check the 20 clicks, MPS is an X factor it holds vacuum, hasn't been tampered with, and is correct for 73 2.0 I tested the harness and parts when the motor was out.
6. FI idle mixture set to spec - on most D-Jet 1.7 or 2.0 L motors, this means setting it to 3.0 %. To do this properly requires a shop-quality air/fuel gauge, an IR-dispersive one at a minimum, or a 5-gas analyzer. You should be able to get a local shop to do this for you for cheap, it takes a few minutes - make certain the car is FULLY WARMED UP when you do this (i.e. run for at least 30 minutes prior to the measurement). Once the mixture is set, set the idle to 950 rpm with the bleed screw.
I'm going to have to get to my friends shop to have access to a CO analyzerThe item that stands out first and foremost is the retard cell on my dizzy. It doesn't hold vacuum, so its not hooked up just capped off at the TB. Also I should be clear, I have no decel circuit parts. Can I use the vacuum retard canister that aircooled.net sells or do any of you FI guys have an extra one, correct for a 73 2.0?
