QUOTE(meador36 @ Mar 22 2007, 05:42 AM)
I agree however I could not locate where they should have been either. I looked in the areas that were on PP and checked Haynes as well, but I did not see them.
Get a bracket and install it because eventually due to weight of pressurized cooler, vibration, and road bumps your cooler will move/work the seals and you will probably have to replace again within about 20-30K mi. or less. Torque setting for the three 10mm mounting nuts is 5 ft-lb (Wilson, How to Rebuild Your Volkswagen Air-Cooled Engine, pg. 149), not much so there will be too much movement without the bracket. John
