QUOTE(Cap'n Krusty @ Mar 22 2007, 08:54 PM)
Channel Lock item #410 is what you need. BTDT, on PLENTY of stripped CV joint bolts. Your FIRST mistake was using a Torx tool, but you already know that. This question comes up more often than any other subject, and the answer is always the same. Seems lots of folks don't search the archives.
Link to the tool:
http://www.channellock.com/acb/stores/1/NU...ER_8482__C6.cfmThe bigger one probably won't fit, the smaller one fits better but may not have the leverage you need. The design makes the jaws get tighter as you apply force on the handles.
Hope this helps you!
The Cap'n
I have always wondered what that tool was designed for. I got one from my retired uncle who worked in HVAC, so I figured it had a special purpose.
Learn something new every day...Thanx Cap'n
sears remover wont even fit.
this car is about to be the most frustrating thing i have ever attempted. haha.
the gap between the bolt and the center of the driveshaft isnt big enough to fit the boltout. no amount of hammering helped.
NEXT?
You are to mad and you are not going at it the right way.
First off, get the thing up in the air so you can turn the wheel (axle) and position each bolt to the easiest access angle.
Next, this is the first thing off, last thing on, so take your time and get good at it..all VW's with IRS use this bolt...and you gotta learn how to do it right.
I will assume that you are working on the transmission side, not the wheel side.
If you are on the wheel side...see the end.
First, clean everything with PBBlaster. Go get a can.
Clean the head, and the back of the stub axle.
You will see that the bolts go through the stub just a bit, and you can see the back of them.
spray that up and let it sit, do it two or three times in one day to get the bolt plenty lubed up.
Now, go get a real pair or channel lock vice grips. not some cheap ass chinese rip off that the teeth are softer than a babies ass...you need real teeth and hard ones.
this bolt is hardened, so you need a good tool to grab it, with hardened teeth.
Spend the money. it will last for a long time.
These come off, no matter how stubborn, with time, lube, heat and vice grips.
If you turn the wheel, you can fit any tool you want in there, up to two feet long...
So if your easyout, or other tools wont fit, your approach is from the wrong side of the axle, wrong angle.. I can sit on a milk crate and do these from outside the car...so I KNOW that a long extension works..it may not be correct, but it works for me.
If you are working on the wheel side, set the car down, take off the large nut on the outside of the stub axle, on the outer wheel bearing.
Remove but hitting that stub axle with a BFH and have a piece of hardwood in between the hammer and the stub axle...
Rich
