QUOTE(TROJANMAN @ Mar 23 2007, 10:07 AM)
what part of the tunnel?
you should be able to lift the little plates and get a hand in there, or remove the shifter. if it is furter back in the firewall, then try and push the new one through towards the shifter, where you can get a hand in to remove the old one.
IT's actually stuck in the firewall area. I can't push it. But I'll take apart the shifter and see if I can find it there.
Thanks for the heads-up!!!
