I've been driving my 914 alot the last few weeks and I have two problems. It seems that the driver's door when it opens up, drops a little....requiring half the time that I actually roll the window down a tad so that the glass doesn't catch when I go to open up the door. Similar scenario when I go to open the door, the glass catches again unless I lift the door slightly when opening. Is this an adjustment to the door hinges that needs to be made?
Secondly, it seems that the sway bar (or) some suspension component on the driver's rear makes an annoying tok tok tok when you go over bumps and is really bad when driving on gravel roads.
Any suggestions?
Charles Navarro
LN Engineering
http://www.LNengineering.com
Aircooled Precision Performance
