biosurfer1
Mar 24 2007, 11:28 AM
I recently converted my tail shift to side sift and once I got most of it back together, realized the rod that goes through the firewall isnt going to work and needs to be replaced. I have tried every way to get it out without having to drop the motor mount bar with no luck.
Does anyone have any tricks or tips to get it out without dropping the motor bar? Its a pain for me to do that so I thought I'd check one last time...
Thanks!
r_towle
Mar 24 2007, 11:36 AM
Have you tried to jack up the motor...gotta unbolt the engine bar..
Rich
TROJANMAN
Mar 24 2007, 11:52 AM
Were you trying to use a tailshift rod?
Have you unbolted it everywhere?
two cone screws and at the shifter?
You can try putting a little lube near the firewall, but it should just push out.
Or are you hitting the mount bar, because of length? Is that the problem?
More info please
push it real good...........
biosurfer1
Mar 24 2007, 12:56 PM
Trojan,
You got it, the rod is completely disconnected but is too long and hits the motor mount bar when trying to slide it out. I tried to gets it turned to slide out through the hole in the motor mount bar but it wont make it.
I have a bad feeling I'm stuck dopping the motor mount bar:(
TROJANMAN
Mar 24 2007, 01:01 PM
i've never done this, but have you tried going the other way with it?
Is there enough room in the center tunnel to go forward, then out the shifter hole?
biosurfer1
Mar 24 2007, 01:31 PM
I can get it into the tunnel, but I cant get enough angle to get it out... who designed these damn things anyways!!!!
TROJANMAN
Mar 24 2007, 01:32 PM
well...............you're not going to use it again, right?
There's not exactly a big market out there for tailshift bars either. Cut the damn thing
biosurfer1
Mar 24 2007, 04:47 PM
hm... never thought of that. Only problem is when I need to get the replacement in, I'll run into the same problem. Great idea though, thanks.
No big deal, just more time to get the damn thing off jackstands. On the plus side, I installed a new primer kit for my jetski and everything worked great the first time I tried, has to be one of the first times that ever happened...wish the 914 would work that way too!!:)
JWest
Mar 24 2007, 05:36 PM
Yes, you will have to drop the engine mount bar to get the new side-shift bar installed.
Chris Pincetich
Mar 24 2007, 06:26 PM
I'm doin the tailshift conversion now too - I might even finish tomorrow!
The Lumpawalii Blog (go to Classics, find post, click in signature field link) has an excellent article on this, and many other projects. That account of the process states the engine must be dropped to fit the front rod in...the front rod doesn't come apart inside like the early one does. I'm sure you could get away with just dropping the bar. As you know by now, the mounts are not easy to access! I have my front rod in, connected to the shifter coupling, and new Rennshift as icing on the cake. I found it really nice to link the shift coupler to the front rod on my workbench for a test fit. I then puffed in some graphite dry lube (that I bought for shift bushings) into the splined hole on the linkage - it should REALLY help with the shift adjustment. What's wrong with your rod?
Good luck!
biosurfer1
Mar 24 2007, 06:36 PM
the end that connects to the coupler must have gotten mushroomed out at some point. I did not test fit it before I put it in, know I know better. I have tried filing it down to fit but no go. I got another rod and it fits the coupler well, so I'll put it in soon.
thanks everyone
