QUOTE(Spoke @ Mar 24 2007, 09:50 PM)
Where did the mechanics work? Sounds like a wire is loose. The sender is under the engine in the taco plate. When you say wiggles, I assume that the gauge goes from engine temp to cold and back. If the sender was open circuited (loose wire), the gauge will read cold.
Spoke
I agree.
Look at the areas where they may have disturbed a wire.
Check the temp wire as it passes through the engine sheet metal under where the battery lives. There is a single wire that connects to the harness there. If the wire leading down through the engine sheet metal has any cuts or abrasions, it may momentarily short to ground causing all kinds of gauge readings.
Other than that, as the others have said, look for loose wires:The sender wire, the ground wire, and the sender wire at the taco plate.
Good luck.
