Question2: 2.0 transplant motor started-up then...
Turn key, injectors click then crank and engine ran for a little bit. I turn off engine to check for fuel leaks etc...car wouldn't start...no fuel pump noise...fuse blown...replace fuse...blew again...swapped relays...fuse blew again??
So what do you think? Car ran perfectly before motor transplant (1.8 to 2.0). Has the fuel pump gone south...or could there be another issue?
PS I disconected the heater blower just in case it was part of the issue.
