Finally got to do some work on the V8 car I picked up, starting with patching the front floor pan to help air-flow.
Before, you can see the A/C hole under the muffler. Why would air go through the radiator when it could just go out the hole in the floor?
Trimmed up the replacement pan and the floor in the car. The opening was cut with 90 degree corners, so the metal was split about 2 inches up the corners.
Now the pan is tacked in, it's not lined up perfect but this will never be a concourse car. Not too bad for my first time doing any kind of body work. I do need to go back in with my wire wheel and clean stuff up. I keep melting tar and stinking myself out of the garage. Live and let learn I guess.
Dan
