I have eleminated my oil leak from the pressure sender, but I am still getting a few drops on the pavement when I have it idle for a while, and am getting quite a bit of smoke blowing around the cylinders. When I look up at the engine I can see oil on the cyllinder fins and the tins, but the head and the tubes are clean (except for a little just below the cylinders) This is on both sides of the engine. I also have oil coming out of the lower opening of the fan housing and a line of oil coming from the front edge of the fan housing. Is is possible that I have oil leaking somwhere in the shroud and the fan is blowing it down over the cylinders? Here are some pics.
Passenger side
Driver side
