QUOTE(rdauenhauer @ May 28 2008, 10:26 PM)
Now for the questions:
A is a OE part Ill have -
-yesB is a part of the OE rod Ill cut off my existing shift rod
-yes1 is a NEW JW only part
-yes2 (same)
3 (same)
4 (same)
5 is a OE ball cup bushing?
-yes6 is the OE shift coupler cover I would have?
-No - this is a JW part7 is the OE console cover I would have and modify
-yes8 is one of two OE shift rod shrouds I have and or can buy from you or ?
-yes9 is one of two OE U joings I should have
-yes, from 914 steering10 Is wher Im unclear!
These are (OE?) knurled rod ends that need to be welded in place of existing OE set pin ends on the (bent) R. (intermediate) shift rod ©?
sort of - you could cut equevalent parts to these from a 914 steering shaft. These get welded to a short center section of the bent factory shift tube.I though the point ot the kit was to eliminate the spaghetti bender rod and replace with a straight rod connected by U joints?
Not exactly. You still have to get around the engine (on a 4 cyl). Half of the bends are removed and the remaining tube has very little flex.
