QUOTE(will @ Mar 26 2007, 01:44 PM)
where do I get butyl tape? homedepot?
do I have to remove the trims on the side where the seatbelt bolts to? The top trip must be remove.
all trim needs to go, backpad needs to go, seats out (makes it *much* easier) ...
buy the buthyl from a auto-glass shop, they have the right stuff.
clean off old crap, clean thoroughly with alcohol or similar, then lay the buthyl bead starting at the top center of the frame, all the way around.
clean glass as well, press glass firmly on buthyl, make sure it seals all around.
this is best done with another set of helping hands ...
Andy
