So, L-Jetronic uses pulses on the ground side of the coil (normally) to trigger the double-relays which then fires the injectors. Appearantly this doesn't work with the Mallory MSD or MSD units because their tach signals are +12V.
Anyone have experience making an MSD unit work with L-Jet?
With the Hyfire all hooked up I tried:
Tach signal wire (yellow). Nope.
Coil Negative (small black). Nope.
Points/breaker wire (white). Nope.
Normally the injection wire goes directly to coil negative.
Can anyone assist? Cap'n Krusty? Jake? Bueller?
Mucho appreciated if ya can
