Hey guys, I've got another question about dealing with RUST!!!
I got these mufflers on ebay for my bike, but they have a good deal of surface rust that needs to be addressed before I put them on.
Anyway, they have two parts I guess you could say: a black painted pipe, which is rusty on the outside and a little bit on the inside; and an apparently aluminum can, which is alright on the outside, but the baffles on the inside are all rusty.
I'm not positive that the can is aluminum, since I don't know much about anything, but I think it is. I can tell you that the cans aren't magnetic and the pipes are.
Anyway,
Here are some pictures:
Here's where it would attach to the common collector:
Here's where the black pipe and the aluminum can meet:
Now here is a look at the inside. It was pretty tricky to get these pictures to turn out!
This is from the back end. You can see the rusty baffles down there.
Here you can kind of see some light surface rust on the inside of the pipe
And finally here's a view from the back, which didn't turn out as well, but you can see the rusty baffles anyway
SO ANYHOW, that's the situation. I'd like to at least get all the rust off the outside and repaint so it looks halfway decent before I install them.
What do you guys think of that rust on the inside? I imagine it will only get worse if I ignore it, so what can I do? Is there some chemical I can spray in there to neatralize it or something?
PART 2: I'm also thinking about painting the aluminum part black as well, because I think it would look better all black. Is the procedure for painting on aluminum any different than painting on steel?
I have ruled out getting this stuff ceramic-coated because I'm on a tight budget.
Now, here are the supplies I have at home so far:
A sandblaster and plenty of blasting grit for it
A little can of POR-15 Black Velvet High-Temp Paint
A quart of POR-15 Solvent (to dilute the paint)
What else will I need for this little project?
And guys, it's safe to assume I don't know what I'm doing, because this is the first time I've done something like this!
Thanks a lot for any help guys!!!
-Chris
