jim_hoyland
Mar 29 2007, 07:20 PM
I've noticed my bursch seems to have gotten quieter over the past three years, is that from soot building up in it ?
When I still had the catylitic converter installed, it would clog up in 2-3 years and have to be replaced.
Any first hand experiences will be appreciated
Jim
Cap'n Krusty
Mar 29 2007, 08:29 PM
WHAT?????? I've never seen that. If you're sooting up a muffler bad enough to plug it, you've got MAJOR engine problems. Busted cats can do that, but that's chunks, not soot. The Cap'n
Joe Ricard
Mar 29 2007, 09:12 PM
My tangerine has changed tune a bit in the last 2 years. sort of mellowed a bit.
jim_hoyland
Mar 29 2007, 09:46 PM
So the change in tone/sound is probably due to the metal itself...OK
Elliot Cannon
Mar 29 2007, 11:34 PM
QUOTE(jim_hoyland @ Mar 29 2007, 07:46 PM)
You're probably losing your hearing.
Cheers, Elliot
So.Cal.914
Mar 29 2007, 11:38 PM
Its shrinking from the heat...Like a wool sweater in the dryer.
Allan
Mar 30 2007, 11:34 AM
QUOTE(Elliot Cannon @ Mar 29 2007, 10:34 PM)
Cheers, Elliot
Brando
Mar 30 2007, 12:16 PM
Cheers, Elliot
Actually Jim, if anything happens to mufflers they rot away inside, or become plugged if/when your catalytice converter's filament turns to fragments. Change in tone? Maybe. More restrictive? Doubtful without a cat.
pfierb
Mar 30 2007, 06:55 PM
Years ago when I was in the muffler business I remember it was quite common for mufflers to loose their new sharp loud sound as they aged....was nothing more than a carbon build up inside.
jim_hoyland
Mar 30 2007, 09:45 PM
QUOTE(pfierb @ Mar 30 2007, 05:55 PM)
Can I clean it out after removing the muffler ?
messix
Mar 30 2007, 10:14 PM
QUOTE(jim_hoyland @ Mar 30 2007, 08:45 PM)
sorry but
but thats funnay
