QUOTE(sk8kat1 @ Mar 30 2007, 09:45 AM)
ok I have the wires hooked up right from the taco plate to the harness the gauge is hooked up right ... the only thing I can think is left is to replace the sender itself .. how often do they fail?
I only found one on PP would that one work with the stock temp gauge ?
Hi Mike.
My guess is that it is not plugged in under the taco plate. I read about 2.8K at room temperature. I assume it goes down with heat (NTC). Do you still have the pot I gave you for the CHT test?. Connect this to the wire going into the harness to the gage. Ground the other end of the pot. This will test the wiring to the gage. If you need a picture of the temperature sensor under the taco plate, let me know and I will post one.
