Fronts have a different offset "depending". Depending on the build date in 72. Rears are the same.
We went through this with a car out East. Rich was going to get some measurements for us because he had ton's of rotors layting around...
I suspected that the rotors could be interchangeable as long as the calipers followed suit. The early (1970-1972.5) calipers have a different offset to accomodate the rotors.
Best indicator is the "Centering Ring" on the rotor. If it has one you generally have a later set up. Early front rotors don't have the centering ring.
Also, look at the calipers. Early calipers have one bleeder and 7mm Ribe head "through" hardware with an 11mm nut on the back end. Later calipers have two bleeders and hex head 7mm hardware with a machined nose for them to screw into (no nuts).
If you use the 75 suspension (calipers and all) for sure, you would order the later parts.
