Pat Garvey
Apr 3 2007, 08:27 PM
While positioning a jackstand under my 914, I inadvertantly hit the RS side marker light with my shoulder. Since the mounting pins are ancient, they broke & the assembly flopped out on the fender.
I was engrossed with other things & simply pulled it loose so I wouldn't do any paint damage. Now I'm not certain how the wires re-hook.
Have the last of my new ones (those damned pins are so flimsy), as pictured, but need some consoling as to the wiring hookup.
See the pic & tell me what you think.
Thanks - Pat
Crazyhippy
Apr 3 2007, 09:01 PM
electrically it shouldn't matter.
I believe your caption is correct though.
BJH
Porsche Rescue
Apr 3 2007, 11:05 PM
Ground to the single spade on the upper right in your pic. Positive to other terminal which contacts the center contact on the bulb.
Pat Garvey
Apr 4 2007, 08:02 PM
Thanks guys! Just needed to be certain - it's been years since I totally removed one of these. Looked straightforward, just needed my hand held!
Thanks again
Pat
