QUOTE(skline @ Apr 22 2007, 12:52 PM)
The U tabs are what the drop link connects to mounted on the control arm. See picture below.
plan on bolting those on today (has existing tabs on lower arms). gotta run the power up front to the relocated fuel pump also before setting the tank back in. this started as plastic tunnel fuel line conversion and we went ahead and moved pump and drilled for the sway bar while it is apart. i also changed trans fluid with redline GL5 synthetic, well see if there is any difference
