I thought I would stiffen the backend of the green 74 with 180LB springs and lower it in the process. When I took the old springs off, it took very little compression to remove them.
As I compared them with the new 180LB springs, I see that they are exactly the same length as the current ones. I don't know what the current springs are. I thought they were stock but they look a lot different than the stock springs I took off the 71.
The 71 stock spring is on the right, the currrent one in the center and the new spring on the left. I measured the spring diameters:
71: 0.382 inch
74: 0.442 inch
180LB: 0.479 inch
The 74 springs have red paint on each of the coils. Can someone tell me what I have on the car?
It looks like I can lower the car a bit with the lower perch. The ring is on the center groove and there's another groove about 1/4 inch lower.
Thanks,
Spoke
