QUOTE(dr914@autoatlanta.com @ Apr 5 2007, 10:47 AM)
QUOTE(orange914 @ Apr 4 2007, 07:16 PM)
whats the general thought about relocating the battery to the front. i've got konis heavier springs and am putting in stock front bar. does the battery relocation actually help or hinder weight distribution? where did you mount your forward battery?
only the factory location. With an optima battery acid spill is a thing of the past and with the tough coat we apply to the tray, then the poly paint and the battery mat, we have a battery located where we do not have to do any special routing of wires, it is close to the starter, it is ventilated and provides the best weight distribution.
Best weight distribution?
The car is a little bit rear heavy. Kenny, why would you want to relocate the battery? Unless you are doing a lot of AXing (and even then its not that big a deal for a daily driver car) I think you should leave it in the back. Its just an unnecessary hassle to run the wires to the front and you also loose some trunk space.
