Yup, mine broke and jammed inside the tube. It was so old that I think the nylon sheathing material broke apart and while pulling it through it jammed up with the head of the cable. I couldn't push it back so I had no choice but to pull it until it broke!
Now about 1/2 way inside the tube I have a bunch of cable, nylon and a section of thread all stuck and it won't drive out. So far I have tried taking 2 - 12" welding rods (welded together) and was able to drive it about 3 " until it just got too tight. I tried welding a small drill bit to the end of the rod but as you can guess, it didn't last too long until it broke.
Next I am going to try a grease fitting on the end of the tube and pump it out but after that I am afraid I will have to surgically remove the tube from the car and replace it.
Any thoughts????
I'm giving thought to trying a Hilti Powder actuated tool to blast it out (22 cal) but I think it might just blow the tube apart!!!
