I want to test my tach without hooking it up in the dash. I just need to know what three wires need to be hooked up to the back of the tachometer on the three prongs. The electrical diagrams are very unclear (at least to me ).
The prongs are labeled
|+12 | +6 (blocked off) | 1 | - |
Here is how I think it needs to be hooked up -
"+12" = 12 volt positive
"1" = Negative from the coil
"-" = Hooked up to ground
If you know, please let me know as I do not want to cook this tach.
The reason I want to test outside of the dash is that I installed an electronic ignition and when the positive and negative circuit is complete, the inline resistor only allows the ignition positive wire to output 8 volts of power to the ignition. Once I verify I can make the tach work, I will add a separate 12 volt positive to feed the wire to keep my ignition wire to the coil/ignition box at 12 volts.
Please advise.
