kckoch
Apr 5 2007, 07:47 PM
They clearly are aluminum. What are they from, and what can they be used for?
kckoch
Apr 5 2007, 07:55 PM
Having trouble uploading pictures. too big.
Aaron Cox
Apr 5 2007, 08:07 PM
great image resizer available in the FAQ tab up top.
davep
Apr 5 2007, 08:11 PM
There are generally only a few aluminum calipers from Porsche. The famous S caliper with 3.5" mount spacing, the 930 calipers and others are generally all others are 4 piston or more.
jd74914
Apr 5 2007, 08:12 PM
Are they these ones? These look like S calipers, but the picture is kinda small.
Picture from blog
kckoch
Apr 5 2007, 08:17 PM
kckoch
Apr 5 2007, 08:18 PM
QUOTE(jd74914 @ Apr 5 2007, 07:12 PM)
Picture from blogI give up, but yes they are.
davep
Apr 5 2007, 08:20 PM
Aluminum "S" used from 1969 911S up though 1974 at least, then on the first two years of 930.
Aaron Cox
you need to resize your pics, try 640 x 480 using the program i mentioned above, or download irfanview.
you need to compress your file size
Aaron Cox
Apr 5 2007, 08:21 PM
those are S calipers. 3.5" spacing as dave mentioned
kckoch
Apr 5 2007, 08:25 PM
As I thought. Good for my GT project? Anyone recommend someone to rebuild?
Aaron Cox
Apr 5 2007, 08:27 PM
they are off 911's ordered with S calipers....
work fine.
eric shea is your rebuilder.
kckoch
Apr 5 2007, 08:34 PM
davep
Apr 5 2007, 08:48 PM
Definitely "S", and the mid production variety. Early and mid had the small nose, and the mid had the X in the circle to designate an improved piston design. Late style had a full width nose. A variety of those was used on the 908 and the 914/6 GT. Just need to use any S strut to use them with the regular 911 or 914/6 20mm wide vented rotor. A very good choice for most 914's up to 250 HP or so.
