QUOTE(2-OH! @ Apr 6 2007, 11:53 AM)
Dave:
It's not that big of a deal...Just come off the hard line with your FI hose and go to either end of the manifold...Just make certain you don't have any kinks, sharp bends or that the hose is rubbing up against anything else (particularly metal of any kind)...Length is up to you and the way you want to route your hoses back and forth across the engine bay...
Pressure into one end of the 3 & 4 manifold and out the other end...Across the engine bay to the 1 & 2 manifold...In one end and out the other end to the Fuel Pressure Regulator in the back left hand corner of the engine bay...Into the side fitting on the regulator and out the bottom fitting back across the engine bay to the return hard line...
I used the Racer Chris lines as well (good luck flaring them for "B" nuts) (Chris, you should install "B" nuts and flare as part of your kit) and purchased a brass reducer fitting at FLAPS...So, hard lines through the tunnel, 90 degree turn after exiting the firewall and then a fitting to reduce the large line to the same size as the small line...Mild steel hard lines bend and twist up through the engine shelf...There are two oblong holes in the shelf right under the battery tray...Must have grommets (buy new at FLAPS if the old ones are shot) through the shelf to protect the hard lines from chaffing on the shelf...Connect hose as above...
I do have pictures at home, but I am not smart enough to post them on this site...Sorry...
Good luck...
2-OH!
10-4, 2-OH, roger that. I've got the: main hard lines, 3/8" rubber line, 5/16" rubber line, 3/8" to 5/16" adapter, grommets, engine compartment hard lines, rebuilt injectors, new injector seals, new 90' injector feed hoses, new clamps.
I'm aware that the injectors don't care HOW the rails are plumbed so in that sense I could route the feed line to any of the four rail-ends. The closest rail-end to the end of the hard line is at the rear of the passenger-side rail and seems to be the most obvious solution.
But my case, with the way I've got everything installed, this routing would force an awkward bend in the tubing. Sure, I could run the line elsewhere, but I suspect that the factory didn't want great loops of fuel line running all over the engine compartment, and neither do I. So that is what motivates my question, to wit: Does anyone have a pic of factory fuel line routing from hard line to passenger-side fuel rail? Come on, guys, this can't be that hard. Surely some kindly CW-type can post this for me? Humor my compulsion this once. Thanks.
-dave
