bd1308
Apr 6 2007, 01:53 AM
Will regular set screws work until I find suitable replacements?
My set screws are boogered up (stripped out somehow)....
I need some set screws....is this a Porsche stocked item?
Porsche should have 'em, and they aren't just set screws b/c they taper- cone screw is the term. I don't think they are at Home Depot, but I haven't looked...
Joe Ricard
Apr 6 2007, 07:56 AM
Just spend the money
get the from any of the 914 parts houses
911quest
Apr 6 2007, 08:22 AM
I have the rear shift rod with coupler and new bushing it might still have the set screw come pick it up with those heads and other misc. crap
Bartlett 914
Apr 6 2007, 08:30 AM
Hi Britt.
I plan on making them. I have a couple you can have. Let me know if you want them and how you want them shipped.
Gint
Apr 6 2007, 09:12 AM
You can make a temp cone screw out of a regular bolt. Got a grinder?
TheCabinetmaker
Apr 6 2007, 09:14 AM
QUOTE(Bartlett 914 @ Apr 6 2007, 08:30 AM)
Why would you go to the trouble? They are only 2 bucks at any Porsche parts place.
Gint
Apr 6 2007, 09:19 AM
QUOTE(vsg914 @ Apr 6 2007, 08:14 AM)
Speaking for myself, if I wanted to get my car on the road right now and a Porsche dealer wasn't handy, I'd whip one up until I could get one. I don't think I would use one forever, but I found one on the zambeziteen that has worked perfectly well for the more than one year that I've owned and driven the car.
TheCabinetmaker
Apr 6 2007, 09:22 AM
If I was down, I would too. It sounded like Mark is gearing up to make them to sell. Maybe just the way i read it.
Bartlett 914
Apr 6 2007, 09:40 AM
QUOTE(vsg914 @ Apr 6 2007, 07:22 AM)
I may sell them. At $2.00 each there is not a lot of motivation. When you need something like this, shipping costs or driving takes time and money. I have a small shop and I can make these faster and cheaper than I can buy them.
Tobra
Apr 6 2007, 09:48 AM
that is why I bough spares. They are so cheap, why not get 4 instead of two when yo uorder them, toss the ones you remove from the car and have brand new ones to use, just in case.
DOn't forget the blue loctite
brer
Apr 6 2007, 10:17 AM
If it doesn't fit right or is loose it is a short walk to having a worn out shift rod.
the vibration from the transmission will wear the tapered hole the set screw fits into.
BTDT
TravisNeff
Apr 6 2007, 10:36 AM
The set screws have a hole in the side (where the threads are) where they press in a plastic dowel, it acts sort of like nylock. Only so many R&I before you need to replace them.
Bartlett 914
Apr 6 2007, 11:05 AM
QUOTE(Travis Neff @ Apr 6 2007, 08:36 AM)
I have never seen that. I will look for it. That is simple enough and is a very good idea.
Cap'n Krusty
Apr 6 2007, 11:12 AM
QUOTE(Bartlett 914 @ Apr 6 2007, 07:30 AM)
Hi Britt.
Why? Howya gonna do the plastic locking insert? The Cap'n
Bartlett 914
Apr 6 2007, 11:28 AM
QUOTE(Cap'n Krusty @ Apr 6 2007, 09:12 AM)
Hi Britt.
I would drill a cross hole and press in a small nylon pin.. The loctite blue is still probably the best solution but the pin is still interesting. As to why..Who knows? For that matter, why am I repairing this old rusty car?
Cap'n Krusty
Apr 6 2007, 12:16 PM
QUOTE(Bartlett 914 @ Apr 6 2007, 10:28 AM)
Hi Britt.
I dunno about you, but MY time is certainly worth more to me than the couple of bucks you're gonna save, and the OE pins fit right, have the correct taper to assure a snug fit and to orient the rod correctly, and they don't fall out. And you don't NEED loctite! The Cap'n
Apr 6 2007, 12:20 PM
QUOTE(Cap'n Krusty @ Apr 6 2007, 10:16 AM)
The Cap'n is right. they're self-locking when new. the only time i use loctite is when i don't have a new setscrew and i have to reuse the old one.
in a perfect world, they are a one-time use only item ...
Andy
Bartlett 914
Apr 6 2007, 01:32 PM
Sure enough, there is a small plastic pin to lock the thread.
911quest
Apr 6 2007, 01:51 PM
One thing I do on the rear coupler coming out of the body is put a hose clamp around the set screw to keep it from backing out.
sww914
Apr 6 2007, 02:31 PM
I just smash the hell out of the whole assembly with a small hammer to peen it in. It'll never come out that way!
Brando
Apr 6 2007, 07:45 PM
QUOTE(Tobra @ Apr 6 2007, 08:48 AM)
Loctite? Try anti-sieze... How many screws have you had to drill out because that cone screw's head has stripped out because the screw rusted in place? Drilling then having to repair the rod or the coupler.
bd1308
Apr 6 2007, 08:17 PM
My screw is stripped out....
im goign to try a oversized allen wrench (5mm) then go to the easy outs.
911quest
Apr 6 2007, 09:05 PM
QUOTE(bd1308 @ Apr 6 2007, 06:17 PM)
If that doesn't work buy a set of reverse drill bits they will catch the screw and usually spin it out
Cap'n Krusty
Apr 6 2007, 09:17 PM
QUOTE(911quest @ Apr 6 2007, 12:51 PM)
A couple of passes of electrical tape work, too. The Cap'n
Tobra
Apr 7 2007, 08:05 AM
They will still back out without blue loctite, ask me how I know
They won't be as prone to rust if you put the boot back on to the firewall. When I did my shifter bushings, had no trouble getting cone screws out, and they clearly had loctite on them
