hedgehog
Apr 6 2007, 10:28 AM
I have a leak where the resevour line connects to the master cylinder...it looks like there is a plastic gromet where the line goes into the m/c. How does the line connect/seal to the m/c. Can this repair be done with everything still in the car ? Is there a good source for the gromet/seal ?
So.Cal.914
Apr 6 2007, 10:33 AM
The line just pushes into the rubber gromet. It's not hard to drop the M/C,
replacing the gromet would be easy from there. Not much room to work up
in there but I guess you could try.
hedgehog
Apr 6 2007, 10:39 AM
QUOTE(So.Cal.914 @ Apr 6 2007, 09:33 AM)
so it sounds like the best way is to drop the m/c, replace the gromet and just put it back together..
So.Cal.914
Apr 6 2007, 11:04 AM
How old is your M/C? if original you might want to just replace it as normal
preventive maintenance. When dealing with your brakes it's not good to wait till they fail.
TheCabinetmaker
Apr 6 2007, 01:02 PM
SoCal, ya might wanna consider giving Gint your avatar. His is surely evil.
So.Cal.914
Apr 6 2007, 01:40 PM
I made it for him, I am just keeping it warm until he's well enough to use it.
Hammy
Apr 6 2007, 03:40 PM
I'm thinking you'll definitely have to drop the master cylinder down to pop the grommets back in or replace them.....
It was an absolute hellish PITA for me to get those two grommets in even with the MC unhooked outside the car. I know some have had similar experiences.....
www.pelicanparts.com has the grommets you need....
hedgehog
Apr 6 2007, 04:15 PM
QUOTE(Hammy @ Apr 6 2007, 02:40 PM)
a friend of mine is going up to Hayward tomorrow and I called Parts Heaven and they have them in stock also....should be able to work on it this weekend
thanks for the input !
